-   -   Rim Mods!!!!! (http://tinyrc.com/forums/showthread.php?t=20326)
Drag00n 10-13-2004 06:11 PM
Rim Mods!!!!!
Hello, i was wondering if there was any mods to change the wheels? Im kind of tired of my stock wheels. I want some pretty cool rims/wheels i see in this site! Anywho are there any mods that do not require any cutting or drilling? Where i can get some cheap wheels or rims for toys r us and just swap them? I wanted Zipzap rims but there too expensive cause i have to buy the whole car. Thanks
Matic 10-14-2004 08:50 AM
Pullback rims are ok...
http://www.toyeast.com/v2/prodlist.asp?catid=700
or alu:
http://www.sedent.de/catalog/default.php/cPath/44_45
frizzen 10-15-2004 11:22 PM
If you want ZZ rims on a Bit, get the "Performance Booster Upgrade Kit". 3 axles, 2 motors, 3 torsion bars. Nibble the end off the outer center of the rim so you can get a pin through it for your steering wheels. The rear axle is either a direct swap, or you have to nibble just a hair off the spacer opposite the gear. (I don't remember)
A while back someone turned the chrome 8-spokes into chrome 4-spokes. works best with a tiny saw and a file.
Hotwheels has some great rims/tires if you're not above a little drilling. Also some great ones for monsters.
Lego has some that work well for monsters, again drilling.
