-   ZipZaps SE (http://tinyrc.com/forums/forumdisplay.php?f=121)
-   -   do zz bodys work on zzse??? (http://tinyrc.com/forums/showthread.php?t=20200)
sharkman_081490 09-23-2004 04:40 PM
i wanted to kno if a nisan skyline from the 2f2f kit would work on a zzse???
DailyDriver 09-23-2004 10:00 PM
fits beautifully....
obviously you realize you are sacrificing the lights which everyone does anywayz , but to answer you questuion yes it fits perfectly and look goods, i like to run the skyline body with the f150 rims or the chromed out 911's
kehern15 11-05-2004 05:22 PM
does the zzse body fit on the zz? i heard that it look awkward, and sits very high on the chassis. :confused:
micro kid 11-06-2004 06:01 PM
i was thinking about doing this if i manage to get a ZZSE since we just got a new F150 glad to know it works
smoakbomb 12-24-2004 09:00 AM
OMFG THANK YOU SO MUCH YOU SAVED ME FROM SPENDING ALOT OF MONEY IN THE FUTURE AND FROM MORE HOURS OF THINKING WHICH ONE TO GET!
Azimov 12-26-2004 05:34 PM
You can squeeze a light harness from another SE donor body in there too. You can either drill the headlights and tailights out and put the bulbs behind the holes, or scrape the paint off the top of the bodie's headlights and taillights and coat them with gloss clear with an artists brush. This looks the best if you are careful with the scraping.
ax0n 01-05-2005 01:41 AM
For what it's worth, the only non-SE bodies I have are the old F&F RX7 and Eclipse, and my original ZZ Mustang Cobra from a few years ago.
First off, the antenna hole is on the wrong side. Not much of a problem, but it does shorten the antenna up a bit.
Next off, The cobra body does not work on the SE chassis. The rear wheels rub. You could modify it with a dremel grinder or hobby file though. Just don't expect a 100% perfect fit every time when putting SE bodies on non-SE chassis and vice versa.
