State Your Gear/Motor Combinations
1 Attachment(s)
I have a green axle and NOS motor combo. What about you?
And heres a pic of my car (again lol) :D |
Mine....
ZipZaps:
Supra: Turbo motor (2.1), red gear Civic: Turbo motor (2.1), red gear Microsizer: S2000: Stock |
Motor Gear Combo
Honda Civic NOS with 9.86:1 green gear
Been using NOS+Green on my ZZ, also like the Red/Red, when I get another car thats probably what ill put on it
i have
NOS motor/red gears it works ok, it still doesn't have great speed. :( although RadioShack did good by putting in the gold wheels in one of the tune up packages. now i'm bling blingin ;) |
well i have one that set up nos &green
but my fav is my other thats red red i dont know why its just all around better quick off the line and stays strong till the end |
my setups
for some reason, to get 'matched' speeds/acceleration from a 27 and 49:
27MHz - NOS motor (yellow)+green reducer+blue axle + treaded tires 49MHz - Red motor + blue reducer + red axle + slick tires - wood (maple) floor surface; these combinations provide less 'spin-out' and better matched racing - both cars weighted down with 3V liIon for brakelight LED mods |
I use the NOS motor with the blue gears.
My girfriend uses the TURBO motor and green gears. Mine's quicker off the line, but hers can take me on the long run. Our cars are pretty equal on our 1/4 mi. track. And what's this about mixing gear colors? Is this legal? Safe? Ect.? |
i use turbo/red
Okaaaaaay, well back to the topic.
I switch from Red/Blue (acceleration) to Yellow/red (top speed) Depending on the conditions. The lower blue gear is definately more fun in the twisties. :D |
silla |
i use the red motor and the blue gear at the moment. i think ill keep the blue in for the most part. im gona either go buy a microsizer today or a k.i.t. racer for parts. depends what the kid wants to do today.
gear/motor
microsizer pcb, stock microsizer motor, red gears in my zip, super fast, about to do dual batt mod
i try using the nos and red gears, but it turns like %^&* and has crappy acceleration.
Gear motor combos
I have noticed I can get the effective speed and turning when I match tires,susp, motor gear combos. Working on chart will post when done.
However what works for me may not work for others. |
| All times are GMT -5. The time now is 03:14 PM. |
