6-celled my car!
1 Attachment(s)
like the title said...i 6-celled my civic chassis. all i can say is holy crap. i didn't even charge the batteries after i took em out of the package and it flew. i cant wait to see what its like with fully charged batts! now i just need a beater body so i dont mess the chassis up! any donations are accepted
the setup of my car is- civic chassis stage 2 drift motor AWD with stock rear end and stock rear diff (that solves the AWD turning radius issues) double suspension up front( 2 springs on each side, car makes real tight turns now) cxp front racing deck and home made antenna |
yea i was amazed when i switched over to 6 cells. you could probably step the gears up a bit too and not loose as much acceleration as compared to the 4 cell setup.
btw what kind of top front deck is that? looks cool whatever it is. nice z in the background too. |
hmm when i did the 6 cell mod my throttle wouldnt work, just the steering..yet when i change it back to 4 cells the throttle works again...
maybe u did it wrong
well i just took out that black wire and put positive to negative and negative to positive...
if you think a 6 cell setup is fast wait till you get some Li-Ions. Much faster.
Mike. www.performancexmods.com p.s. Im getting my first shipment of Li-Ions right now! They should be here within a few days. |
1 Attachment(s)
found the perfect body for my 6-cell. it provides plenty of ventilation as u can see
1 Attachment(s)
Does the extra weight of the batterys mess up the handling? I would think you would need stiffer springs to compesate. I am thinking about using the lith ions instead. Any suggestions?
i love my 6-cell xmod!
ill buy li-ions soon. |
How'd you go about the twin shocks?
| All times are GMT -5. The time now is 04:11 PM. |
