-   -   No one talks about the 3.2 (http://tinyrc.com/forums/showthread.php?t=1955)
d00kie 10-14-2002 10:34 AM
I would like to know about this intriguing motor. Speed, torque and whatever you know about it. Also, the sites decribe it as Tomy manufactured so is it? I don't see it on ebay etc.
E)(pul$ioN 10-14-2002 12:28 PM
KC (BitChar-gMotors) makes it. Its quite good, but you should ask him fo more info on it or go this site: www.bitchar-gmotors.com BTW, he was da original maker of it. ;)
payaso 10-14-2002 12:32 PM
I use the 3.2 in my ganster bit and it works great. Give it a try... Better yet, buy one of each... You can never go wrong with one of each
silla
ericb49 10-14-2002 01:47 PM
The 3.2 is a great all-around motor. Another option is to use ZipZap motors (the Turbo (2.15) or NOS (2.35)) in your bit, both are as fast as the 3.2 with the ZZ motors having quicker off-line power. Radio Shack charges ~ $12.00 for a ZZ Fast N Furious Tuning Kit, comes with both motors plus other parts that can work with your bit (Stabilizers, tires, gears).
d00kie 10-14-2002 02:40 PM
The ZZ NOS motor is equivalent to a Bit 3.2??? HOW???
ericb49 10-14-2002 02:45 PM
The ZZ board puts less than half the current to the motor than the bit does...so a motor rated at 2.35K RPM @ ~ 90mA will rage at 200-ish mA!
323iT 10-14-2002 03:22 PM
I drove E)(p's 3.2 and its almost the same as the stock 3.0... i can't really tell the difference after the speed of 3.0...they're all just hella fast:)
