Someone Help i've got a flat
Hey guys. I have a HUGE problem with my Acura RSX. When you look at the front of the car the passenger's side front tire looks flat (I know the tire can't be flat but the body sits that way). Anyone have any solutions???
stronger springs or check the spindle if its in place.
i have the stongest springs available on it....what's this about a spindle???
i will try that thanks for the advice
i dont know if you thought of this but did you try using a different tire somtimes hard cornering at high speeds will do this to tires i was racing on a asphalt parking lot and was maybe hitting 25 and hard left and then when i went inside to rebuild the drive-train i noticed the front right tire was looking a little odd so i walked down to RS and picked up the Tire Upgrade threw on a new tire and good as new if that is not your problem it may be your wheel if it is i would just rotate the wheels or if you dont got enough cash to buy the tire/wheel upgrade just rotate your tires thats what i did once when i was broke (which i always am) i hopped this helped
naw... it came straight out of the box like that. i tried changing the tires springs etc. but nothing really helped. then i changed the whole front end suspension and everything to the old one on my supra. it helped, but not much. plus i did the dual lights mod and now they rub so i have to sit down one day to check em out
Come to think of it... this would be a good time to work on an anti-roll bar that actually works unlike past attempts. |
| All times are GMT -5. The time now is 02:24 PM. |
