-   ZipZaps SE (http://tinyrc.com/forums/forumdisplay.php?f=121)
-   -   dual celling a SE (http://tinyrc.com/forums/showthread.php?t=19096)
merc-blue 04-15-2004 05:50 PM
dual celling a SE
so heres the new... rumors are that the PCB is regulatored to 3V right seeing im getting my first SE in a couple of days i cant check on this so if u want to dual cell it properly then i suggest replacing it with a 5v regulator (casue 5v is probly the highest safe voltage for the PCB) just a simple swap.. if your a aussie then you can get them a jaycar (SMD Voltage regulatr they have 3 types just get the 5V) and u yanks can get them somewere im sure.. i just dont know wat shop u have.. becasue if u dual cell and u cell pump out 6 volts you only get the performance of 3 volts but if u put in a 5V regulator then you get the perfromace of 5 volts.....
