-   -   1970 fast & furious charger. need help (http://tinyrc.com/forums/showthread.php?t=19071)
jdizzy204 04-12-2004 08:15 PM
i just bought a amt/ertl charger from wally world and i wanted to fit the body onto the xmod chassy. now im only 16 and i dont really hav ne experience with this, so plz bear with me.
can ne one tell me:
where r the best places to cut.
and
what materials i need to do this mod.
any help is appreciated. thnx
97Supra 04-12-2004 11:04 PM
you want to fit the charger with the body and chasiss?
jdizzy204 04-13-2004 07:30 AM
no. i want to use the shell of the charger and put it over the xmod chassy. if i wasnt using the right terms, let me kno.
97Supra 04-13-2004 01:53 PM
can you give me a link of what it looks like then we might be getting somewhere
jdizzy204 04-13-2004 03:00 PM
http://www.hobbylinc.com/htm/amt/amt38033.htm
97Supra 04-13-2004 05:43 PM
I don't know how to mount it on the chasiss but some where in the xmod fourm someone did it
micro kid 04-13-2004 06:36 PM
have you tryed to fit the body with out cutting? if it does interfere where does it interfere and how bad is it. dont worry about only being 16 im only 13 it just takes screwing up and learning what to do or not do . the materials you will need are a knife, a ruler, various files and sanding tools. i like to use a pair of side cutters for big cuts that dont have to be perfect
P.S. you have carbonfiber chassis under comming soon in your signature twice
jdizzy204 04-13-2004 06:56 PM
yea i hav tried fittin it and i need to find a way to cut out 2mm of the body without ruining it. i thought about cutting 1mm from each wheel well but i dont kno how it will look
jdizzy204 04-14-2004 03:55 PM
no prob. and thanx for helpin. i wuz just about to start cuttin:eek:
jdizzy204 04-15-2004 03:51 PM
Awesum. Thanx a million.im gonna go 2 hobby town sat. and pik up sum stuff so i can start. BTW duz neone know which 1:24 dubcity cars come w/ spinners?
eLeMeNt_sK8er04 04-16-2004 10:40 PM
NOW WAIT UP HERE!!!! AMT/ERTL???
If you got an AMT/ERTL model it should be very easy to mount it on an X-MOD body if its soft plastic
thats all i have to say!
jdizzy204 04-19-2004 02:17 PM
hes got a point. just because one amt/ertl 1:25 scale car might have fit on an xmod chassi w/out a problem, doent mean that all cars of the same scale will do the same.:rolleyes:
xmodsman 04-19-2004 08:05 PM
no no no no no no
u got it alllllllllllllllllllllllllllllll wrong
you dont cut the body u extend the chassis
u make plastic tabs to lengthen the chassis and put them in between the back and front peices of chassis
(Then u extend the drive shaft IF U WANT AWD TO WORK otherwise just take out the driveshaft)
DarkPhoenix 04-27-2004 09:23 PM
man, mounting a die cast body on an xmod would weigh it down a LOT....but if your just doing it for show then good luck.
jdizzy204 04-28-2004 03:13 PM
wtf r u talkin about????????? its not die cast. its plastic
