Help with the light's
After removing the lights how can I give them a smoked look but let the light from the light kit show up.
A quick shot of black spray paint from a few feet away is the only thing I can think of. You're going to risk ruining your headlights, though.
I was looking at towerhobbies for black paint and i found this.
http://www2.towerhobbies.com/cgi-bin...?&I=LXNV75&P=7 |
I guess you could get that stuff. Just make sure you mask the front of the lens, and just paint the back.
I forgot to ask what you would recommend to take the red stripe of the civic's tail lights.
The only thing I can think of is to use brake fluid...but I doubt that would work. Brake fluid works best to remove spray paint.
All the thing's I can think of that would work also would tern the plastic white or make it really soft.
I may give the brake fluid a try and see how it comes out. But thank's for all the help RC 2NR. |
dip the tailight in rubbing alcohol for 30 minutes. take a pocket knife and gently scrape off the red stripe. use clear nailpolish to get rid of the scratches and clouding
if you want a color smoke effect you can use a sharpi, i used blue and it looks nice
Thanks for the help guy's. Seeing that the electronics just fried in my xmod I'll have some time to work on the body's now.
| All times are GMT -5. The time now is 05:52 AM. |
