Bit - Digi - SmartLand
1 Attachment(s)
Here is my colection.
iRacer are comming. The Pic is from my 7650 so not too perfect ! |
1 Attachment(s)
Here is a "close" look of:
Digi-Q Smartland Bit-Charg Bullet (modified) putted with force a big 1/3 AA NiCd 120mAh |
1 Attachment(s)
My B Track !
125x80 cm Record 3.28 sec with Bit-Booster 3.0 |
did you make the side of the track out of these bendable rulers for sketching?
Is that a lap timer/counter?
I have been considering making one for my ZZ track out of the laser point and photo cells, using different height flags on the cars antennas to trip the laser beams. I have seen this setup for the Mini-Z cars.
Curious what your timer/counter does and how it works. Work only for one car? Must explain!! Pic of my track: http://www.latencyproject.com/zipzap.../track_010.jpg |
Hey, nice tracks both of you! :cool:
Could you describe them in detail? Size, materials, construction, etc... Thanks! |
The "latency" track look more cool then mine,but: - It is my first track - I have invested little money and just 3 hours on building (manly because I changed my mind about the track shape 3 times !) - It is very light (no more then 100g) How it is done: The black base is what it is normaly used for be putted between the raw flor and the carpet, I found it on "House Building Shop" (BauMax) : 3$ for 125x80x0.5 cm. The black base is a sort of "expanded rubber", 0.5 cm thick, very very weak, but for light cars like the bit, it is not a problem. The blue lines come out of a "multy purpose" carpet, it is made out of stronger "expanded rubber", that I have easly cutted with a knife. This carpet 100x60x3 cm was little bit more expensive (15$) but can provide me enough lines for 4 or more tracks ! The lines are not glued on the base, since in case I change my mind I can redesign it ! The lines are just connected with small nails with a wide flat cup. For be sure to don't lose nails around the flat, I just use a easy removable scotch tape on the rear side, this fix better the nails and also help on not scratch the flor. Cost for the small track : 8$ plus 2 hours ! I'm going to build up a bigger track, using to bases (160x125cm). Plus drugster track (250x40cm). e_lm_70 My record is now lowered to 2.8sec with Bit Booster, the only way to drive a Digi-Q on the track is to set the maximum speed at 2/8 using the Special controller. |
| All times are GMT -5. The time now is 09:20 PM. |
