Bodies for M-Chassis
Does anyone know the mm for the M02? Also, can anyone tell me the mm length thing for the following bodies? The Civic, Pajero, Suzuiki Wagon, the VW BUS, and the Polo or Golf body. Also which of these bodies would POSSIBLY fit even when not PERFECT? Thanks
Re: Bodies for M-Chassis
Yeah all of those are from HPI. (i guess) Which bodies would fit my m02 chassis?
What about the Suzuki Wagon body? Will that fit my chassi?
i am not sure.......i need to dig alittle more.
i do believe the suzuki wagon r is 210 mm. but youre in luck, the m02 chassis also came in the m-02 m chassis. which is basically the A chassis part opposite the gear box. the m02 M is 225 mm wheel base so you can use civic bodies, polo, gti .. like me! are you able to find those other bodies you listed? id like to get my hands on a bus body and or a VW gti... oh, if you need the m02 medium parts.. let mek now, i have a spare. btw, tamiya bodies that are 225 mm wheel base are the alfa romeo guilia sprint and the honda smx lowdown.
Wait enomator... so your saying that my m02 chassis can fit BOTH 210 AND 225mm bodies? IF i have the m part something? Cool, but if i need the m part thing, can i buy it from you and how much? THanks!
yes, it would fit. right now, my car is an m02-M car, started out as an m02. well if you have the medium part, then you can use the 225 mm wheel base. youd have to change it back to the m02 short/standard to use 210 mm bodies. umm, i was thinking maybe around 5 bucks or something plus shipping. i dunno. let me make sure i still have it first.
5 bucks seems ok with me. But where does the m part go into? Are there instructions and how much would the shipping be? Thanks.
well its quite simple. you know the part opposite of your gear box? on the other end of your chassis? the part that your steering setup is hooked up to? thats the parts thats different. its just a longer version of that part entire case thing. ill post a pic if i can. but shipping should be around a buck or so. and i dont have that piece.. so let me know. drop me an email.
there is also a performance gain. it should also give more stablity with the sacrafice of agility, with the longer wheel base.
| All times are GMT -5. The time now is 09:25 PM. |
