steering
i hit a wall at full speed, my steering doesnt work anymore... it works in one direction tho, but not as good as it used too, i think one of the gears might have broken or something??? anyone else have this happen to them?
if one of the gears are broken the motor wont turn the servo. try turning it. if yo feel any sudden resistance when moving it. turn it gently, there will be some resistance. if moves very easily you have a stripped servo. if ther is some sudden resistance then you have some dirt in the gears. or you could take the servo out and remove the front cover. then just take out all of the gears and check them. while its out check the wires going to the PCB board.
| All times are GMT -5. The time now is 04:07 PM. |
