"Diablo" PaintJob
Check it out! I just painted my Corvette C5-R. Its a little big but its ok for me:D. I kinda messed up on the sides tho, and i need a way to mount the body. If you have suggestions on a way to mount the body, please post it here.(BTW: the rear is not purple, its bright red, but for sum reason my cam couldn't capture it.)
The Body: http://www.miszou.com/Upload/96/323.jpg On the Chassis: http://www.miszou.com/Upload/96/324.jpg The Rear: http://www.miszou.com/Upload/96/327.jpg Top: http://www.miszou.com/Upload/96/325.jpg Side, You can see how the body is not a perfect fit: http://www.miszou.com/Upload/96/326.jpg Tell me what you think |
Kinda messed up on the side? IMO it looks sweet that way!!! BTW, it looks awsome!!! you know ur get this question but........How'd u do it!? :D
Paint job is sweet.
I would definately find a way to stretch the chasis. Make some mounts that can be attached on the front chasis to main chasis and allow them to be seperated further. You'll have to make a longer driveshaft as well, but if you contact Sluggbug, he may be able help you with that via a custom CF shaft. I'm doing an eXMod as well. I'm planning on using the stock rear mount/clip on my model body as well as use the stock front tab to attach to the body. Details still haven't been figured on, but there will be pics when completed. |
The paint job is nice, but you should have used the Mini-Z body. That model body is not even close to fitting. Time to build a chassis extension plate and a longer driveshaft, and then try to make some wheels with the proper offset.
He could probably flip the wheel inside out to fill the fenderwells and have a meaner looking deepdish look :)
Atleast, thats the easiest way to cater to the empty fenders. |
looks kinda like a funny car to me lol
hey SuPrBuGmAn you play paintball? i think i recognize ur name from the pbnation forums from forever ago |
wow! i have 5 different bodies now for my xmod. I just found an Audi TT heipao mini-z body and a '68 corvette. They both fit well. Ill post pics up tonight and ill paint the audi a "space" color.
suggestion for mounting your body
not on an x-mod. It looks stupid
NIce MICRO RS4 BODY!
Good painjob, but have a good time trying to convert 1/28 to 1/18 scale |
| All times are GMT -5. The time now is 04:31 AM. |
