-   -   i wish my xmod could do mad donuts like that! (http://tinyrc.com/forums/showthread.php?t=17486)
skklown 01-14-2004 08:48 PM
here in akron ohio its snowin like mad. after jazz band today at about 8 ,my friend took me to go do donuts in his v8 gmc sierra. after we unloaded the bed so there would be no weight we went mad. Wuts a good way to get my RWD skyline to do supermad donuts? i know about using scotch tape but i need sum really grippy front tires otherwise all i get is half donuts. any suggestions
charliebrown 01-14-2004 09:07 PM
Grippy front tires?
If your racing on hard, smooth, flat floors, like indoor tiles or hardwood, then use the soft tread tires, found in the rubber tire uprgade kit. Make sur your floor is clean, and here's a quick solution:
take the tires off the wheels and get a bowl of hot water. Let your tires sit in the water for about 30 seconds, then take em out and dry them in a paper towel or regular towel, whatever. Bow drying is not recommended :D
put them back on, and see how they run. From the hot water, they should be a little softer and give you a grip on the road.
If you're going on the flat concrete, on the tennis court, or outdoors, go for the hard tires. Good luck!
Chuckster...
Comrade_Boris 01-14-2004 10:00 PM
your in jazz band too??? i play piano in my high schools jazz band :D
in down here in oxford near cinci........mind send a bit of you snow to us? all we have is rain and ice......
spinitsidewayz! 01-15-2004 01:21 AM
scotch tape is a good idea. also you should try locking ur diff or just converting it into an lsd then you can pull off doughnuts like nothing. and stick with drift gears.
raytard 01-15-2004 01:46 PM
i just got a sno day upin ny..... try a vinyl floor like in ur kitchen or sumthin and rty puttin no tire on the rear, or wrappin the tire in a rubberband, andthen scotch tape, so it will be like ( = )instead of | = | so theres less to touvh the ground ^^^ view from tpof tire
skklown 01-15-2004 05:40 PM
well i got my car to do crazy donuts and spinouts. i masking taped the rear wheels and cleaned off the front wheels with a damp cloth. it was awesome
TypeZer0 01-15-2004 05:54 PM
try the foam tires in the rear
neurokinetik 01-15-2004 06:11 PM
You mean like this? This car is AWD with soft rubber slicks. The key here is excessive power to the wheels, and a fairly slick surface. :)
http://users.adelphia.net/~neurokinetik/ras.avi
TypeZer0 01-15-2004 06:33 PM
lol, omg, that's nuts haha have you tried gunning it straight for like 20 feet than turning hard and make it spin like crazy?
skklown 01-16-2004 10:30 AM
that vid didn't work for me
neurokinetik 01-16-2004 12:32 PM
You need the Divx codec installed to play it.
http://download.divx.com/divx/DivX511Bundle.exe
adiosk8r13 01-16-2004 03:59 PM
I have a tile floor so if I just put a little bit of water onthe floor I can do insane donuts.:bgdr:
skklown 01-16-2004 04:48 PM
neurokinetik....thats some crazy stuff there on ur video.....is that a gym floor?
neurokinetik 01-16-2004 07:00 PM
Nope, it's a roller rink. I've got more footage, but I need to finish my other video before I can start editing down that stuff.
skklown 01-16-2004 08:57 PM
k
post the longer vid here when its done....cant wait to see it
