Left Cup JOINT???
my lefft rear wheel is wobbling sum one said its the left joint cup or sumting can any help me how to fix it im me at AustinSwish08 on aim or post
the same thing ihas happened to me and i have no idea whats wrong with it
mine wasnt wobbling at all an it just fell out
all you need is to find some washers that'll fit on the axle. put them between the wheel and bushing/bearing and that should stop it. just dont tighten the nut too tight.
its not working
how many washers and how thick were they. they have to fit almost perfectly on the axle or you will still have a wobbly wheel
Mine did that as well. Washers didn't work for me either. After closer inspection of the wheel I found that the D shaped hole was rounding and very little of the D remained. Changing the rims solved my problem. Inspect to hole and look for damage.
| All times are GMT -5. The time now is 05:36 PM. |
