paper clutch LSD!!
EDIT: I recommend trying my type 2 design. much more consistant lock and no power loss;) all you need to do is place 1/4 inch punches flat against the center plate between the 3 little pinion gears. no removal of parts cept maybe for the little differential pin. just stick them in. paper, plastic or metal :)
tired of diffing out with that old open differential?;) ok well earlier i was mad cuz i kept diffing out so i took apart my differential n tried to find a way to make it an lsd. i acctually considered gluing the gears in place. [locked differential] well long story short!:D i saw my hole puncher on the corner of the desk... ok here we go! 1. take apart that open diff 2. take out the pinion gears [small center gears] 3. flip side gears [gears on the sides] so the toothed side is facing outwards towards the axle. 4. between the flipped side gear and the center gear holder thingy [ring gear?] put a little stack of hole punched paper [the lil holes that go everywhere when you hole punch :D ] find the number of "plates" you like. [more you add the more "locked" ur differential is.] 5.repeat to other side 6. sandwich dhat thing together and start driving :D [i dont think youll need that lil metal pin anymore so you can put it to the side with the pinion gears] its almost like a real clutch type lsd! on my dusty garage floor i can drift and slide pretty nicely :p oh yeah first post! just thought i'd share:) |
hmm i was just thinking...
i could try different types of paper for different diff. characteristics.. |
sounds awsome. but how will the paper allow the diff to slip occasionally, also a pic would aid in the concept
Isn't it awfully hard to get a stack of tiny pieces of paper (chads, actually) to stay in place when you're installing them?
sorry i dont have a digi. ill see if i can borrow my friend's.
well when you turn, the lil papers act like clutches. it'll slip easier or harder depending on how many you have in there. the idea is like a real clutch type lsd. you could try looking around the net and look at some kaaz cuzco diffs. the "clutches" lock against each other while still being able to slip a bit when you turn. if you put in enuff, like around 6 or 7 each side itll act like a locked diff. around 3 or 4 and they're slipping alot especially when you punch the throttle going straight. i only acctually thought of the idea and tried it last night. im thinking 5 chads would be enough for a reasonable lock.:D and yes it is kinda tricky to get them to stay. these little things stick to ur fingers sometimes. if you stack them like a sandwich and then hold it together while you're screwing the whole thing back together it isnt that hard. 6 - 7 locked 4 - 5 slip i started out with 4 each side. i noticed also after a night of driving the "discs" wear down maybe just the paper becoming more compressed against eachother. so i added some and moved to 6. maybe it was too much. im gonna try 5 or maybe it just has to "wear in" the paper im using is the printer kind. |
technically speaking....
1 Attachment(s)
your exzactlly right with the theory/concept you have. But don't you want to try some cardboard mixed with posterboard I figured out the exzact same thing you did awhile ago and I tried different types of combos. You ever played GT3 they have 4 diff slips a oneway, 1.5way, and twoway then the custom slipunit. take posterboard and mix it with cardboard and it's pretty much like a oneway lock so to say. now take poster board and a few punchouts of paper and it's like a 1.5wayslip or you can make a two way slip type by taking two pieces of poster board. Make shure the slick side is noted where it is and face two posterboard shads together and with the shiny sides facing each other you have a certain type of surface tension this surface tension if modifiable with the white grease lube. Also use some testors paint thinner or something not that abbrasive and clean you diff first and use percision when applying the grease. Discard or store the pins that connect the two diff shafts together in a safeplace. Now you have a posterboard slip diff (PSD) and the best thing about it is that it doesn't compact a much as I found with the paper shads but the paper shads kind of put that .005 non special touch to it. Cusco slipdiffs are awsome and that Sakura is to.
Good material idea's guys.
I am using the instructions from the xmods to cut circles out that are the same size as the the 2 flat gears and put them between the spider gears and the flat gears. You have to oil the paper to give it a smooth and consistent slip. I'm using machine oil but any oil should do. I tried cling wrap and zip lock baggy plastic but they would just clog up the works and cause a full lock and were a bitch to clean out. I'll try the hole punch idea tonight, thanks |
if you flip the spider gears around so that they point in the other direction, it wouldln't mesh right wiht the ring gears because they're bevel gears
hmmm well i was tinkering with my differential again today and i had my auto mechanics book open:D to make a true lsd i would need to put the whole differential back together again how it was. to make it an lsd i would just put paper discs between the side gears and the differential casing so they would fit around the axles. this would obviously take more time then the hole punch idea because you would have to cut the little ring discs urself but it would be more like a real lsd. the discs would slip against eachother and the diff. casing. im going to try making my own discs and see if this works. kaaz lsd http://www.kaazusa.com/images/kaazlsd.jpg |
That's mighty complicated. What's turning the final ring gear?
hey you guys I have further info for materials that I have been testing with.
Peanut butter plasic tubs the white plastic types have lots of flat surface for many lsd's it's the same type of plastic that is used with some 20. oz. coke tops and the like. Plastic as I have found is very interesting you can make a locked plate disc connected to the shaft inside the spoke hub(discarding the bevel gear thingys). that rubs off on a center plate (center plate measured and huned at *__* thickness) made out of anything plastic posterboard papper etc. and then the same thing is vise versa on the other side. it's identical on eash side. A stronger (less slip) diff in front is better along with a weaker diff in the back. That is to say with awd kits of course. now just how to adapt this to a Tamiya dual gear box. Sinistar keep it drifting!!! |
ohh, i get what you're saying now, i was thinking that you reverse the three little gears, not the bigger gears that hook up to the drive shafts
sinistar these are some great material ideas. have you ever tried metal washers? i found some that had the right diameter its just that theyre not thin enuff to work in the diff. |
hey that diff pic is awesome. thanks I'm printing it now. Metal washers hum I could file the thickness down depending on what thickness they are. TZero+everyone I have been developing the slip diff types with only using the outside spoke hub, and the back outside hub. In eliminating the inside layer piece that regularly supports the 3 spider spokes you can start to see just how much space there is and just what type of plates/layers you can start to stack together. The whole softer flexable plastic thing doesnt really cut that well. So I'm looking for other materials but metal washers would be one material to be used in my next design since they are in fact used in the suggested back diff in the AWD kit. hey do any of you have ideas for drift tires.
Sinistar |
i just figured a new design for the paper idea. i found a 1/4 inch hole puncher and the punches fit right between the lil gears. so the little punches fit against the center plate and push the side gears to the outsides of the diff. works much better then the inverted plate idea. all you need to do is insert these lil thingies while ur putting the diff back together. it is kinda tricky. yeah and the only part of the diff you dont use is the little metal pin.
| All times are GMT -5. The time now is 06:26 AM. |
