Stage 3 of my xmod
1 Attachment(s)
Stage 3 of my work, pure speed! My fet's are mounted on the motor heat sink. The blue can you see is the 10,000uf power Cap. Mounted on each side is 2 CR2 lithium batteries
Be careful of that... You can't have the tabs of all four transistors attached to a metal heatsink without using some kind of insulator. Otherwise you'll short out the motor output, possibly taking the FETs out in the process.
that's pretty cool it looks like a big pile of batterys and wire
I glued the fins of the heat sink to the motor heat sink, the car runs fine. If something was wrong, my batteries would have heated up really bad and give off a smell. neurokinetik, do you happen to aim?
No I don't use any form of IM... |
whats dose a power cap do?? and whats the highest cap that i can put on
whats the huge capictor for, and whre does it connect to etc?
That's some crazy stuff! Where'd ya get ur fets and what type are they?
| All times are GMT -5. The time now is 05:58 AM. |
