aaghhhhhhh!!!!!!!!!!!
When I order my RSX body for my Skyline chassis do I need to buy a driveshaft, and what number is it?
You know I was wondering how they do that, they should just have the right shaft in with the body.(it will be really stupid if they dont include it)
I know you can adjust the length of the body, so I'd assume if the skyline chassis is longer, then you might need to get a longer driveshaft too, as it's what holds the pinion gear in place. Alternatively, you might be able to fabricate some kind of thing that holds the pinion gear in place if you're just RWD.
I also noticed that on my chassis, the front clip that slides into the slot on the front of the body literally says "Skyline R34" on it, so that part may be different between models as well. |
Re: aaghhhhhhh!!!!!!!!!!!
Alternatively, you could just buy a set of slugbugg's CF shafts... |
Yah, thats a good idea
| All times are GMT -5. The time now is 03:34 AM. |
