[Pic] What ZZ PCB is this?
I just bought an original ZZ with a Camaro SS body. I was thinking about getting a Perfection 4.2 and I want to make sure my PCB supports the motor. This PCB does not look like the V1 & V2 pictures that are posted on this forum. Any ideas?
http://www.rbartick.com/cf/zz_pcb.jpg |
You have nothing to worry about, that is the new PCB. If it's the new Camaro SS, then it's definitely capable of handling the 4.2.
Chuckster... |
You will be fine running any motor currently available. It is about a version 4 or 5 if they are up to 5 yet.
Yeah i have one of those too i havent modified anything on my zz yet but i think ill start with the actofgod laymans battery mod before i throw in a 4.2 or any other engine stronger than the stock motor. So that pcb can handle any of those mods mentioned right?
Yes, it should.
I went to Radioshack and they let me salvage 2 batteries from broken cars on the counter. While I was there I bought a tuner kit with the Purple NX motor.
I wired up the dual batteries in series with solder tape and installed them in the car with the Purple NX motor. I had to flip the PCB in order to get the body back back on. The car is now uncontrollably fast even with the stock blue gearing. If I try to turn while giving it power it flips over and goes flying. The car now will even run fast on carpet. I do not think I need a faster motor. http://www.rbartick.com/cf/zz_pcb3.jpg |
what if the pcb looks the same but it has a yellow wire for the antena instead of the red one. is it still a modifiable pcb?
Good Grief.....:rolleyes:
A yellow wire and a red wire on the PCB for the antenna means they are different FREQUENCIES....it does not alter the chip in any way, except that they run on a different signal. :rolleyes: Chuckster... |
You know that was just kinda pointless post and I don't evan understand what you said?:confused: I think you are just trying to bring your post count!
Any way, if your gonna put a pointless post eatleast put some word in it like I did! LOL:eek: :D |
ok before posting PLEASE! read the new one
| All times are GMT -5. The time now is 08:23 AM. |
