Steering.
I want very tight precise steering the spring upgrade-bearing upgrade ( soon the all wheel drive upgrade ) will be enuff for tight a** steering? like turn on a dime hehe mine turns on a us dollor peice ( a silver dollor hehe )
so can you guys help me out???? |
the only thing i know to do is use the 4.5* toe-in. or you could mod one to your likeing. btw, the bearng upgrade will only make you go faster, not turn better. (pretty sure anyway)
Agree with RSXRacer - use the 4.5 toe in steering doohickey for tight steering. Just beware that it will be tighter in one direction than the other. Can be a problem when running a direction with the car where you can laterally exceed the tires traction very easily.
These guys are correct. a 4.5 tie rod is needed to have tight steering. AWD will help keep the car from fliping over.
Awd will not keep your car from flipping. To do that change to softer springs.
softer springs? are you sure about that? the softer they are the more grip you have, the more grip you have makes it more likely to flip. seems like it would be harder springs to me.
| All times are GMT -5. The time now is 11:40 AM. |
