how do you widthin a body
i found the nascar body in the dollars store it is perfect but it is not wide enough it fit help please !!!!!!!!!!!!!!!!!!
Is that even possible. You'd have to recreate a whole middle part from scratch for it.
if you good with sanding, and cutting (and if you want to.. you could cut the body down the center ( long ways) and add a strip of plastic to make it fit, then use a sodering iron to attach everything together, and sand her smooth, hope i could help
You could definatley do it, you just need to cut the body down the center and fill it in with plastic or putty. you should put too much on, and then just sand it until it's smooth. I would also pu tin some suppors going sideways to make it stronger.
yea i agree, good hunting
Cutting it from the middle and adding some plastic wont make it look good. You'd have to bring the window indented like the car. Make the front bumper look the same, and the back bumper along with make the curves the same...
thats kind of why you sand
Putting one long piece of plastic and sanding that won't work. Think of getting the sanding paper in the bumper cracks?? m hmm -_-
| All times are GMT -5. The time now is 04:43 PM. |
