Boasting Range?
I did a fairly amatuer mod with copper wire that worked well enough to give me about 20 feet range. Are there any other, better mods?
Thanks, -Alex P.S. i love my efini. I would highly recommend it. |
If you can solder (which I cannot) you can replace the controller's antenna with a tellascopic antenna (availiable at RatShack). You can also do a Cat5 antenna mod... http://www.rcmod.com/mod1.html
Re: Boasting Range?
what is this mod that gave u 20 foot range
Sorry for leaving you guys in the dark. I have been having internet problems. Anyway, after much testing, I'm sorry to say it doesn't seem to have 20 feet range. I thought it did, but it seems to fluctuate. Basically all I have done is quite crudly exposed the end tip of the wire antenna of the ZZ and twisted it qround a 3 inch or so piece of copper wire. They are intertwined together, if you will :) and i also used a piece of tubing from a lego mindstorms set as strength. Its good enough for me.
sorry again to get your hopes up. Its still better then it is stock. -Alex p.s. i will post pictures soon of my intitial D body and the efini chassis to show what the antenna looks like. |
I have never experienced this good of performance personally but
I read somewhere that the zz se is suposed to have a 44 foot range in optimum conditions. optimal conditions- -antanae perpendicular to ground -no obstacles in between the controller and car. supposedly this changes a lot though. my 2 cents by the way my car has a guitar string antanae that increases range a little bit. |
I usually get pretty good range with all of my Zaps (49mhZ, 27mhZ, original as well as SE). Prolly 35+ feet or more. Here's where I drive mine, on the concrete driveway out in front of my house. Standing at the garage door (POV in this pic), I can drive my Zaps almost out into the middle of the street.
On zipzaps.com it says that SEs are supposed to go 40 feet!
| All times are GMT -5. The time now is 12:06 AM. |
