AWD help
I jst bought the AWD upgrade,before I install it I wanna knoe all the trick to it, like something to do with leaving the stock diff when u upgrade it? please give me tweaking tips on how to have this baby fly!
Put it on like you would regularly but put in the stock differential in the back (that is the white one) dont put in the red one. Do the front like it tells you to. I have heard of some people puting the red diferential in the front and they said it makes your car go faster but i havent tried this yet. If you put the red one in the back it wont steer right. Dont ask me why it just dosent.
I got a problem, only three wheels move the front right barely move....plz help I left the stock def in the rear
Hmm...make sure that everything is installed correctly. The gears in the front may not be meshing properly.
another Problem
i fixed that problem already they all turn, now another problem it turns to much to left then the right, I left the stock dif in the rear like i've been reading on some other threads, I jst don't knoe wat to do
*P.s. I also centered the steering servo long time ago so that can't be it. |
can it be the tierod?
I guess your best bet is to reassemble the AWD and then assemble it again.
reply
try adjusting the strange on your controller
Re: reply
should i re assemble it? all part look correct. I think its the tierod, cuz i got the 4.5, and both front wheels are aligned like dat Example: > , not that togther though but u knoe wat i mean still turns more left then the right |
| All times are GMT -5. The time now is 10:07 PM. |
