-   XMODS Parts and Hop-Ups (http://tinyrc.com/forums/forumdisplay.php?f=126)
-   -   all-wheel drive (http://tinyrc.com/forums/showthread.php?t=14946)
turbopimp187 11-11-2003 01:04 AM
all-wheel drive
i heard that getting the all-wheel drive kit decreases top speed. doez it really slow u down or iz dat just a rumer?
Hudson5150 11-11-2003 01:29 AM
It does slow you down but not much if you leave the stock (white) differential in the rear. The payoff is greatly increased handling.
turbopimp187 11-11-2003 04:35 PM
thankx
weba2nkill3r 11-11-2003 05:36 PM
Is it good to get a awd?
4G63T 11-11-2003 08:26 PM
Yes!!!
viperkilla 11-11-2003 08:45 PM
Like Hudson5150 said, your speed slows down alittle bit but not too much. But this gives alot of handling.
Stormvet 11-17-2003 02:18 PM
I've noticed that the speed has reduced minimally but the biggest drawback I've seen is that my turning radius has decreased a LOT! If I want to make a sharp turn I need to slow WAY down. I'm running soft tread tires, hard springs in the rear and soft springs in the front.
The BIG plus to the AWD kit is that you don't spin out (oversteer) nearly as bad.
