would this work?
i was thinking of replacing the steering spring with a cut paper clip or staple...i would have to bend it closer and glue it on.
should i just try it? i thought about this, because my zz has a slightly bent sterring spring...i had to bend it back in place... |
The paperclip and staple are a bit 'thick' as a steering spring.
You could try this: http://www.ausmicro.com/technical/bi...ring/index.htm |
| All times are GMT -5. The time now is 07:29 AM. |
