-   -   5th cell... has anyone seen this? (http://tinyrc.com/forums/showthread.php?t=14548)
merc 11-03-2003 08:48 AM
1 Attachment(s)
I found this guy trying to sell this xmod with 5 cells. This is what he wrote:
"A holder for a fifth AAA battery. These were made to use 4 AAA batteries. If you use standard 1.5volt non-rechargeables that is 6volts. If you use NiCd or NIMH at only 1.2volt per cell you end up with only 4.8v. This modification will let you add a fifth nicd or nimh cell to get a full 6Volts! This has not been tested with 5 alkalines which would give a whopping 7.5v, you can try that at your own risk for even more speed."
I was wondering if anyone else here has seen anything else like this or has tried it.
EMX 11-03-2003 08:51 AM
It wouldnt be that hard,
what is the max voltage these things can take?
merc 11-03-2003 08:58 AM
Not sure. He doesn't sound that sure about useing 5 1.5v aaa's. But i thought it would be kind of cool to get the 1.2v's back that you lose useing the rechargeable nihm's.
