Mini-z motors
What do ou have to do to put a mini-z motor in an xmod, cause most dont have teath on em and getting the off the xmod motors is hard
You need a pinion puller. You can get one from your LHS. Also you might need a motor press. Basically it puts the pinion back on.
does anyone know if the pinion puller size is 2mm for an xmod
| All times are GMT -5. The time now is 04:54 PM. |
