HELP, and i will give you a dollar!
IDK whats up with my xmod, i was just running it and it started this, i took it all apart and cleaned it, then it still did it, pls help!
http://66.207.2.168/My%20Pictures\car\car.avi |
it kinda sounds like your driveshaft is binding
try lubing the driveshaft bushings at both ends where's my dollar !!!!!!! |
wow
that does not sound good sounds like something is rubbing some where, but with out being there i couldnt tell you where. where is the sound comming from? did you run into something? is an axel rubbing? also it could be a bearing. |
Lubeless driveshaft it was, oh wise one, if u really want that dollar. i suppose i could, lol |
double or nothing on my range problem, i think its the 9v, how long do those typically last?
1st off do you know where the sound is comming from?
If not then you need to start buy applying a small amount grease to the gears if you have not already done that. You should also check to make sure you replaced the yellow plastic bushings on the rear suspension arms off of the stock rear arms (the red rear suspension arms dont come with them). If those were transfered I would next lube the axles. If you car still makes the sound you final step would be to lube the drive shaft. I think that just about covers it. Let us know what happens and if anything I posted here helped. Fusion ps. Dont worry about the buck if what I said works. |
OPPS
I didnt read all of the posts Im glad you got you xmod working correctly. |
| All times are GMT -5. The time now is 06:35 AM. |
