-   -   Body molding (http://tinyrc.com/forums/showthread.php?t=14090)
geofroley 10-24-2003 09:38 PM
Body molding
Me and my friend were trying to make bodies by somehow melting plastic to adapt to shapes of hot wheels. Am I doing this right?
IceSkyLine 10-25-2003 12:11 AM
Melting bodies
1 Attachment(s)
Hehehe that what i did.
I took plastic fender of a matchbox rc car and molded em with real car bondo to the Micro chassis.
geofroley 10-25-2003 09:08 AM
What material did you use and how did you heat it up? Nice body by the way.
IceSkyLine 10-25-2003 09:25 AM
Rear Body flare
1 Attachment(s)
-First i found a car which i want parts from(aka real cars fenders/pumbers)
-2nd i took a knife or clip and cut the fender out.
-I had to drim it so it roughly fit the shape of the micrsizer.
-then u use bondo (real car bondo that u can get by the quart
from any car store autozone advanced pepboys) the bondo acts like glue and also acts like filler for the gaps.
-Sand the exessive body part down to the shape u want and there u go
u have to use a rough sandpaper to get the shape and a fine one to get that stuff smooth
IceSkyLine 10-25-2003 09:28 AM
do not melt ur body just use bondo
1 Attachment(s)
its a gray butty like substance whic u have to mix with a red substance for it to dry.
geofroley 10-25-2003 10:16 AM
Ohhh I see. Thanks I'll try that.
TuRbO_GuY_69 10-30-2003 03:41 PM
what hot wheels car did u use? and a dremel would b fine 4 sanding right? obviously w/ 1 of those cylyndrical sanding bits :rolleyes: .
TIA
IceSkyLine 10-30-2003 09:16 PM
I dont know really
1 Attachment(s)
I dont really knwo what i hotwheel i used.
But here is what is left.i will also use the front bumper of it. its gonna be my front bumper for the accord.
u tell me what is was hahaha
Oh and i used P800, P600 wet sand paper. Sanded by hand. I used a dremel before wasnt precise enough for me but it worked good to clear out teh fenderwell. But yeah a dremel works fine.
Lord_Nick_D 10-30-2003 11:17 PM
I have one of those cars I am making it into a rc car though like I'm keeping the rear end and putting a bit front end on as well as the mid sectiom with pcb and at least 3 batteries
it will be the first slot car motor powered bit
it will be atleast 3 inches long though
IceSkyLine 10-31-2003 01:32 AM
good luck
good luck man !
I am looking for some fenders for the front lol any idea what to use ? or what car to chop down ?
geofroley 10-31-2003 04:32 PM
I jsut though of a new idea for body kits and fenders: Rip them off of Muscle Machines cars and cut them to size they would look awesome.
IceSkyLine 11-01-2003 09:34 PM
hahaha best way to add music to ur ms
use a hit clip radio or a hit clip.
geofroley 11-03-2003 03:38 PM
Little weighty, and limited selection of music.
IceSkyLine 11-03-2003 07:41 PM
Sure is weighty
just add a 3.8 engine some blue gears and the hit clip and ull drive like a 2.0 ?
nice cruising speed with music (note: no bass, all highs)
Lord_Nick_D 11-03-2003 10:12 PM
back to your chop job idea
any plastic cars should be fine
I dont know i your like me and hate extra weight but if not you could use putty
