-   -   what's wrong with my supra?! (http://tinyrc.com/forums/showthread.php?t=13947)
lilcricket 10-21-2003 04:28 PM
the other day, it ran at least 50 ft away with a few stutters near the end....today i took it to the tennis courts finally(let me say very fun first though, hehe), but noticed that it lost signal at almost 25-30 feet, what's the deal, i tried the 9v battery trick, by placing paper back there so it makes good contact, so it's not that, the antenna is screwed securely in place, could i have messed something up when i put the awd and suspension kit in? possibly the antenna wire jarred loose or something at the source end? please help, i need the range back!
Murcielago659 10-21-2003 04:33 PM
Did you install the light set? I noticed that i lost a lot of range with mine when I did that.
digiman32 10-21-2003 04:42 PM
I am running the lights set on mine and have no problem with range. I can run mine all over the tennis court, from one end to the other with no stutters at all.
Murcielago659 10-21-2003 04:43 PM
I don't have a major range loss, I figure at most about 10 feet, but it's definitaly not going as far as it did before I installed it.
SerialKillinSam 10-21-2003 05:00 PM
i only get about 25 feet of range when im out side at the tennis courts inside about 20 and its always been that way since i got it but i never ran my car stock
YeLLoW GT-R R34 10-27-2003 06:54 PM
i lost MAJOR range when i installed the blue stage 2........weird
Bad Company 10-27-2003 07:00 PM
Hmmm.... I've have the AWD and use the both the drift and road race motor and get the same range before stuttering....about 75 feet.
YeLLoW GT-R R34 10-27-2003 09:16 PM
i tried the suggestion from aperson so i changed to the drag s2 motor........same crappy range
