-   ZipZaps SE (http://tinyrc.com/forums/forumdisplay.php?f=121)
-   -   Zipzap se problems (http://tinyrc.com/forums/showthread.php?t=13631)
Geckoboy 10-08-2003 03:11 PM
Zipzap se problems
Ok here is the scoop
i charge my zzse
take it off when its done
then drive around allittle
then after about less then 3 minutes of driving it dies( this is with no light...no nothing)
So my Question 4 u is "what is up with it?"
i have 2 zzse doin this( and am about ready to say back to the old school ZZ)
Char-g Ace 10-08-2003 04:22 PM
to be honest, i have that prob 2.
I like the old schoo, better because it has faster scceleration
Geckoboy 10-08-2003 05:06 PM
kool thx
anyone else???
Btman 10-08-2003 06:58 PM
The first one I had did this and I thought the second one had the same problem until I replaced the batteries in the transmitter. It seems that either something in the original car or original transmitter drained a new set of batteries prematurely. You may have to replace the batteries in the transmitter with new or fully charged batteries (if using rechargeable batteries) to see if this is the problem. You may have to take your car back to exchange it if you still have problems. Also make sure the leads on each light are not touching each other inside the body. If the car is running slower than normal, check for the usual, lint, hair, dust between the wheels and gears.
