-   -   Bit CHar-g motors in ZipZaps (http://tinyrc.com/forums/showthread.php?t=1342)
SupraCruza 09-27-2002 09:04 AM
Namuna I read you compatibility post, and I'm having a hard time adjusting my Bit Char-g motor to work in my ZZ.
Can yo explain how you got it to work?
The NOS motor is way too slow for me.
kwikbb 09-27-2002 09:33 AM
Look at this thread where I explain the problem.
Namuna 09-27-2002 12:05 PM
You definitely have to fidget with motor to get them to fit...But they will fit.
Now, about 'speed'. Are you disappointed with the top speed? or the acceleration?
kwikbb 09-27-2002 01:05 PM
Namuna, did you have better luck using the bit motors in zz's? If so what was the motor size and gear ratio used?
As I had said before I put a 2.6 in using both 9.86:1 and 12:1 ratios, both performed like crap. :mad:
ViperKid 09-27-2002 04:55 PM
could someone explain the color of the gears to me? which one is fastest?
MTL 09-28-2002 01:46 PM
blue accelleration with lower top speed
green standard all around
red top speed with almost standard accelleration
anyways...yep i just got my ZZ and its like a 1.o Bit..NOS motor doesnt even make a difference
sam see 09-28-2002 04:15 PM
ZipZap = ZipCrap
~Sam C.
kwikbb 09-28-2002 05:19 PM
Posted by PhatZap
They both have a 50mah rating and their charge lasts about 3 minutes.
The NiMH in my zz says it's a 100mah :confused:
93civicdx 09-28-2002 08:45 PM
i will
Soon as i get my zip i will weigh it.I don't know about the bits.I have one of those pitney bowes postal scales.
MTL 09-29-2002 01:37 AM
so...the zz is slow cuz its heavy....thats what it seems...
and damn thing is hard to put the chassis in/out..i swear i will break my eclipse soon....
