-   -   Yet Another speed Mod (http://tinyrc.com/forums/showthread.php?t=13067)
DraGula 08-29-2003 11:44 AM
1 Attachment(s)
This mod is very easy, but requires the use of a soldering iron.
1. desolder or rip off where shown.
2. connect the two points left after the part is removed.
3. charge and watch it go!!!
the boost of speed from this mod is minor, but i havent found any downside to doing this though.
(thanks to namuna for the use of the pic!!)
Tazzy 08-29-2003 12:49 PM
I've got a shen qi wei with a PCB that looks the same but I don't have the fancy text nor the black blob... should I go ahead with this mod?
BabyKiller 08-29-2003 01:58 PM
and what does this do take off a resistor to allow more voltage to the motor in other terms a simple semi mosfet?
FoeverClownin 08-29-2003 07:02 PM
do u have a version for the big lots thunder charger clone
DraGula 08-30-2003 01:57 PM
i didnt test the voltage output yet, it should be higher, and this will probably work on clones, it will do the same thing to their electronics.
RobotGT 09-03-2003 05:35 PM
would one glob of solder connecting the 2 points work. im really concidering trying this! good pic and directions
DraGula 09-03-2003 06:59 PM
of course one glob of solder would work, you just need to connect the points.
Clownn 09-16-2003 06:43 PM
i just finished doing it put i did not connect the two points and it still worked do i have to connect the two points so it can work good??
Clownn 09-16-2003 06:51 PM
i just took it for aride ant the reception is the worst it wont even go 2 feet
DraGula 09-17-2003 05:02 PM
that's strange, i didn't notice any range loss when i did this.
Clownn 09-17-2003 05:03 PM
i had to go exchange it for a new one in target
put of course striped it compleatly;)
