-   -   need help for charging pad, which wire goes on the left and right? (http://tinyrc.com/forums/showthread.php?t=12864)
eman1 08-13-2003 11:32 PM
I took off the plastic piece to replace it, and i dunno which wire is which. looking from the bottom of the controller, which one is on the left, blue or red?
rt450 08-14-2003 12:53 AM
ok. with the controller facing you, neg towards you, pos away from you. the pc board will tell you which wire is which.
boho 08-14-2003 04:25 AM
Red on right, blue/or/black on left.
eman1 08-14-2003 07:50 AM
ok thanks, both your answers are the same just said differently so i assume you guys are correct.
