Clone controller question
Alright, I just replied in another post about using clone controllers, and it raised a question in my head.
I'd much prefer to use a $10 clone for it's controller's range then swap a PCB for better range. Witch makes me ask if everyone knows about witch clones have compatable freqs. I would like to know if anyone has found other compatable clone controllers that will work with BCGs. Witch ones have good range, and list them if there's alot please. And lastly, is PCB swaping still better for some? I already know it will offer more freqs in the same band. besides that? I found a clone called cyclona that has 3 of the freqs that tomy uses. When I say compatable, I mean you can actually run the BCGs with NO problems. |
i know shen qi wei's are fully compatable
i have a 27mhz ms and a 27mhz shen and i just use the shen controler for both cars since the range is over twice as much also i changed my brothers 49mhz to a 45mhz to work on a shen controler i've seen shens in 27mhz, 35mhz, 45mhz, 57mhz i think all those are also bit frequencys |
| All times are GMT -5. The time now is 04:17 PM. |
