gears wont mesh properly
every now and then the pinion gear and idler gear on my lxx booster locks up and i have to manually spin it to get it to start working again. how can i fix this???
edit also when it is running why does putting the body on make it stop?? i cant see where it would be making contact with any moviing parts |
had the same problem
one solution was the motor position didnt make the pinion gear mesh good with the idler gear. a shim fixed that problem another time it was just crappy gears. and about the shells, hmmmm.....what shell are you using, alot of my supra shells are tight around the wheels..... |
if you have had the lxx for a while like a month and modded it the chances are that it is just worn. I had one and replaced the gears with microsizer gears at toys r us. also try using a more powerful motor
brand new outa the box but still good call on the crapy gears. couple of the teeth were a bit lop-sided so i replaced it and runs great now. and yes i am using a supra body. also i am using the yellow zz motor(decent unboosted, prety crazy boosted).
| All times are GMT -5. The time now is 10:47 PM. |
