-   -   engine and gear test results (http://tinyrc.com/forums/showthread.php?t=12228)
faulkbeets 07-10-2003 05:48 PM
today i did a test on which was best and i figured that the yellow zipzap motor with green or red gears are best for speed but not handling
civic freak 07-10-2003 05:57 PM
i beg to differ
not 2 b mean but i beg to differ the fastest setup is Nos. Ex. with teal (fast) Microsizer transfer gear with the red Zip Zap axel once again not to be mean wouldnt wont to be on your bad side or nething
faulkbeets 07-10-2003 06:02 PM
lol i dont see what could be mean about it but i shouldve cleaned my nos motor better before running it in the test cause it still had some hairs...which i guess made it slower, thank you
dr1zz 07-11-2003 03:17 PM
the nos xpress motor is pretty fast, but the king 4.2 is faster
but if speed is all you want, do the mosfet mod on just the forward h-bridge
strider_mt2k 07-11-2003 05:49 PM
Re: i beg to differ
Were you aware that they are exactly the same thing?
Both the MS teal and the ZZ red are 8.25:1 ratios.
My fastest has been with the purple motor and the 8.25:1 gearset. It's generally the gearset i use on everything except dual cells. i use 9.86:1 on those for more control.
NatakuARN 07-11-2003 05:53 PM
What is Mosfet
faulkbeets 07-11-2003 06:06 PM
info here http://www.bitpimps.lixlink.com/page...opic.php?t=798
civic freak 07-11-2003 08:13 PM
i beg to differ
they are not tha same strider_mt2k tha teal meshes togetther better i agree its tha same # of teeth but it meshes together better like i said earlier, not to mean be i hate people to be mad at me
dr1zz 07-11-2003 09:03 PM
thoeretically they are the same gear ratio and all, and i find that certain clone gears mesh better with the ms pinion gear
but who cares, if you got no handles, then go straight all you want
strider_mt2k 07-11-2003 09:54 PM
All I use are the black 6 tooth pinions that MS seems to put in every accessory kit. Well, that's not true, strictly, as I use the Zip Zap too.
I haven't seen much diff, but I'l try mixing them up to see.
It is an interesting idea. I suppose I could look at them side by side under a microscope at work too. Not that I'm an expert.
Actually the assumption that they are made idetically, or by the same company was all mine!
tngrt 11-15-2003 10:55 AM
It's Nitrous Express, not NOS Express. Nitrous Oxide Systems (NOS) and Nitrous Express (NX) are competing companies both selling nitrous oxide.
