would this be fine?...
would this be fine for not damaging my car?
the laymans dual cell mod with 34k motor and changin the wires in my controller to let it charge at 3v and charge the car for 5-7 minutes? also how much speed does the dual cell add? lastly how much speed does the tri cell add? *edit* cause my current setup (34k motor and stock battery) runs at about 3mph |
first off, you will burn your motor up very fast. i have a triple laymans cell and use the red motor and red gears and it is fast enough for me.
second, you need a standalone charger. you may be using 3v worth of batteries, but resistors and stuff will keep that from working. you need to build a standalone charger. if you go to the *other* forum then you can find a how to that i made. |
thanks i'll have to look into it
| All times are GMT -5. The time now is 01:18 AM. |
