My 350Z Project
1 Attachment(s)
Here is my latest project. So far, I have lowered the car. Instead of making the cuts in the body, I removed the existing tabs on the chassis, and added new tabs at a lower point. That way I can use any body on it and it will be lowered. Also, I hand drilled the holes in the rear deck for the spoiler.
1 Attachment(s)
nice job! makes it look more streamlined, how did you work around the heat sink screw?
pics of the chassis would be great! Thanks :) |
nice!....where did you get that spoiler...it looks really nice...can you please show pics of the inside?
What do you make the tabs out of and where do you get it?
1 Attachment(s)
As for the heat sink screw, I used a Dremel to slightly shave away some plastic on the inside of the body where the screw would sit.(Some cars don't need this.) I just cut that tab back to the screw and stopped there. The spoiler was from the 2F&2F Tuner Kit. The tabs are made of an old credit card.(IMO, the best use for a credit card.)
My camera doesn't take good close-ups, so I used my scanner. |
1 Attachment(s)
It doesn't look like I have much of a tab in the front, but that's because I stuck stiffiner braces on the top and bottom.
1 Attachment(s)
The white semi-circle line is where I shaved the body for the heat sink screw. Also, I did have to shave the insides of the wheel wells a little for tire clearance.
wow looks pretty good....how did you make it...do you think that i could make it....i am a beginner....well sorta
sweet!!! when you drop in virginia beach we will definitely need your help in making my 350z look as fast as it really is! i also have the button cells i ordered, i'll tri cell yoru car and give youa custom charger. i made an AC charger for myself:D
now to get back on topic: great job! if i can find any old credit cards im going to make a body kit (sideskirts, hood scoop, etc) for my 350z and maybe even my pt cruiser:D |
Sure thing flatlander_14. I plan on making a couple more of the chassis lowered tab mods, and I will trade you one of them or something. I was thinking about adding some side skirts, etc. to this one.
sweet, when you come here, we'll work on your car's performance, and my car's looks:D
| All times are GMT -5. The time now is 11:58 AM. |
