-   -   Steering that refuses to be fixed (http://tinyrc.com/forums/showthread.php?t=11145)
Tillek 05-21-2003 12:08 PM
Here's my problem, my tomy bit turns very tight right, but horribly left. I've done everything I can think of to fix the problem: Cleaning the knuckles, replacing them, new steering spring, two steering springs, making sure the magnet is centered, different suspension bar, no suspension bar...
I noticed that the steering coil on the right side has one of the wires sticking out a little, hardly noticable though- no more than one wire width. The only other thing I can think of to do would be to go to radio shack and do the three rare earth magnet mod so that the magnet is larger than normal.
Is there anything I'm forgetting? The bit didn't used to do this, so at least it wasn't hosed from the start. Thanks!
Awaken 05-21-2003 01:06 PM
take off your back wheels and see if the wheel on the side away from the gear rolls without the axel...if so superglue it on and it should help
Tillek 05-21-2003 01:15 PM
Yea, I checked that too. Just forgot to mention it. It's as tight as a... um nevermind. ;D Any other suggestions? Or must I live with a gimpy bit?
Awaken 05-21-2003 01:18 PM
other then that i think you did it all...did you see if the plastic shock is touching the steering to hard? it wont turn right if it is on there to hard
Awaken 05-21-2003 01:21 PM
ah never mind i over read that part you tryed that too...blah i have no clue unless the left coil is broken some where
hogjowlz 05-21-2003 01:27 PM
is this a bit or a clone? ive had clones that just wouldnt steer nomatter what i did.
id take a larger magnet and just kinda sweep it allover the whole front end to remove any metal dust.
dabigpig 05-21-2003 01:34 PM
Awaken- please refrain from double posting very short posts. instead please use the edit function of the fourm and add on to you're original post to instead make it longer. it gets annoying to read double posts. thx in advance.
Tillek- well sounds like you've nailed pretty much everything i can think of there isn't much else that could be contributing to the problem that you haven't allready tried.
Awaken 05-21-2003 01:39 PM
opps guess im not used to cramming all my info on one post.hehe ill try to stop doing that its just a habit...kinda like talking in a chat room...you dont usually make long sentances and stuff.. will anyway you should try to take it back and get a new one..did it come out of the box with messed up steering?
Tillek 05-21-2003 02:03 PM
Lol, I wish. I've had it for a while and modded the heck out of it, it's been fine until just recently. I think I got it from ebay or toy east anyway.
I'm heading to radio shack sometime soon, I'm gonna try changing the magnet out for 3 rare earth magnets put together, it makes the magnet a little thicker than before, I'll let ya know how it turns out.
Hogjowlz- you have a disturbing name... I never realized it until I typed it. ;) It's a tomy fairlady z. thanks for the suggestion!
thanks for your help guys!
hogjowlz 05-21-2003 02:55 PM
thanks. id just buy an mssport and swap out the chassis.
