-   -   ? bout peak chargerrs ? (http://tinyrc.com/forums/showthread.php?t=11074)
dr1zz 05-16-2003 04:40 PM
pirahna digital peak charger, can you just connect a charge base off a controller to the input and charge that way?
here is the link topirahna charger
flatlander_14 05-16-2003 05:04 PM
i was also wondering about this. i did a layman's cell mod to one of my clones and it is crazy fast, but i think i could get more runtime if i peak charge the batteries. i was wondering if you could use a wire to connect the charge leads of a charging base to the spots where a AA or AAA battery go on a cheap-o AA/AAA charger. has anyone tried this?
dr1zz 05-16-2003 05:38 PM
i have one of those rayovac nicd/nimh chargers for AA/AAA/9V batts. so i made a spacer so the 1/3AAA batt sits snug. this works fine and i get plenty of runtime, but the pain is the fact that i have to open up the car to get the batt out and charge, im gonna break a wire sooner or later.
i tried to connect the charge base to the leads and it wont detect the batt for some reason or other.
i want to buy a peak charger that i can just connect the charge base to and slap the car onto the base. and so far, this pirahna charger is the cheapest one i found that will charge single cell.
ive read that peeps are doing this with other types of peak chargers, most of which are in the ~$100+ range.
flatlander_14 05-16-2003 05:41 PM
too bad it only has a minimum charge capacity of 50mah:( the button cells are 40mah. what if i selected 2 or 3 cells (however many are in the car) and set it to 50mah? would it automatically shut off?
Buzzbait 05-16-2003 06:01 PM
Yes. You can just take the wires running from a charging base, and run them to the bare wire connectors. No problem..
Awaken 05-16-2003 06:14 PM
couldnt you get a donor charger base off a bit controller and connect it to the peck charger so it fits on the bit prefectly? :) just a thought
Namuna 05-17-2003 11:43 AM
1 Attachment(s)
Well, if this picture helps...
This is my Peak Charger (Dymond Super Turbo Charger) sitting on top of my Power Supply, connected to a Bit Char-G charge bay that I modded from a controller.
Notice how I wire from the charge bay to the Peak Charger.
dr1zz 05-17-2003 06:33 PM
dude..........sweeeet........
namuna, nice.........what mA charge rate do you use?
Awaken 05-17-2003 06:57 PM
like i said you should wire a charger base up so you dont have to hold the wires on the car hoping they are touching and charging it :p
dr1zz 05-17-2003 08:48 PM
lmao
awaken........wake up and read prior to post.:rolleyes:
2fast2furious59 05-17-2003 08:50 PM
dude that is awesome
Namuna 05-18-2003 12:09 PM
What I LOVE about my setup is that I've got a charge bay for my Bits, Zips, Maru, Epoch and using battery holders I can charge NiMH and Nicads too.
As far as charge rate goes, if i'm in a rush I charge at 1amp (1,000mA)...But if I want a more proper charge, 800mA seems about right (this is for ALL the different types of Bit batts, whether the stock 50mAH Nicads or the 160mAH NiMH)
Awaken 05-18-2003 01:24 PM
hehe sorry im not to bright i think my light bulb burned out a few years ago ;)
