fixing steering problems
on my duel cells of i dont take off unboosted they will imedditly spin out and when they dont they go like 1foot and spinnout and this is a problem with all my cars with a 2.6 or higher except my motor works which back tire are as huge as ass
lloooooonnnnnnggggg sentence there man,maybe you should try to add a second steering spring cuz that will help the car go straighter and it will be better and much easier to control if that dont work you should consider making it a stright drag racer and block off the steering by getting some rare earth magnets and adding one magnet to each side of the stock magnet that will not allow the car to turn anymore and it will be good for doing straight runs (thats one LONG sentence)
all my duel cells have 2 steering springs except one which has 3!!!!
make your tires CLEAN... the reason for spinouts is loss of traction to the rear wheels... remember, you're going to have dirty tires after about 5 seconds unless you clean the surface ur running on
Hard tires in front help also. I like the ribbed ones from the microsizer tire set. I also like zip zap all season radials from zip zap tire kit for the rear.
i clean them whenever i cant po a wheelie(ever 2min):D
| All times are GMT -5. The time now is 05:58 PM. |
