flippin Civic
i'm havin a few problems...i just got my new track finished but now when i drive my zip on it it flips on every corner. none of the bits do that just the zip zap. What can i do to keep it driving good but not flipping? thanks;)
I would say, either slow it down a tad, addsome weight, or try different tires.
HTH ~Mike |
thanks mike...i'm going to try a harder front susp. thing ( don't know what they're called)
hey mike you live pretty close to where i live:D |
Let go of the gas as you turn.
I've noticed that my Zap turns sharper than my bits. The steering set-up is just better.
it also is my only zip with microsizer wheels..would that have anything to do with it. i tried my other zips and they didn't hardly flip at all
here's the set up: x-men zip zap (faster than other zips) microsizer wheels and tires orange gear set (microsizer) honda civic body NOS motor tortion bar soft (three holes) |
Nos motor isnt really made to turn that sharp. use it for strait races.
ok i'll try with the red turbo motor
When I made a tricell Zip, I put bit front wheels on it and it actually retarded the steering a little. I liked it though. It didn't flip over anymore. The Zap steering was sharper. My MS Pro has the ZZ steering in it and it turns much sharper than it did before.
chelboed your zip zap must be retarted:D :D
sorry couldn't resist i put the red motor in and it does better, but it will still flip every once in a while |
I had MS steering knuckles, and it made my steering all goofy too. I also had to use a MS steering arm, because I broke the ZZ one. It messed with my steering geometry, and the wheels pointed out. Now I use steering knuckles from a a clone, with the MS steering arm. I had to dremel he insides of the clone steering knuckles to get my steering range where it should be, but the steering geometry is perfect, with a tiny bit of toe in, and using the oversized clone steering knuckle with MS wheels and steering arm helped remove some of the slop.
I'm very happy with the way it handles, considering the mess I got myself into, transplanting steering coils, and using parts from different cars, I was going to consider myself lucky if I got the steering working at all, but it all came together great, to my surprise. Now if I can just get it to stop flipping. I'm going to get some pullback wheels before I put a third cell in it, but I'm wondering if the weight from the third cell will help hold it down. |
if you put the weight low it will help, but if you put it on top of the car it will most likely worsen the flipping
Do this mod to your car: http://www.tinyrc.com/forums/showthr...ighlight=bunta
| All times are GMT -5. The time now is 11:48 PM. |
