Motor Works
i got a new little toy its a motor works pickup
i put small front tires all around i was wondering if i could put a different motor in it |
Those motors are hardwired, right? Well, you probably could, just take the wires off of the old motor, and put em on your new motor, simple as that.
i could just solder them on? or will that mess the motor up
It shouldn't mess the motor up, just don't hold the soldering iron on there for too long, it might overheat it.
but i got a 3.2 and it has a small metal piece on the endbell instead of the normal big ones
does any one kno wut the motor works motor is? |
Yea, you solder one wire to the end bell, and the other wire to the motor casing, or the heatsink. And make sure they are on the correct way, or your car will be going backward...:p
i did it but i had to remove the extra white power wire
also wut if i unhook the light and hook that to the motor too would that help any??? ......im thinking it would just add torqe but i unno right now im working on a :bdrop: and also i thnk im gonna buy a dual cell bit (or ZZ ifthey will sell one) from rcmod.com |
Huh? A light? Sorry, I don't have experience with Motorworks cars, but just remove it, it will give longer life to your battery.
1 Attachment(s)
HeyWorld,
So was your 3.2 motor any faster than the stock motor in there? Those trucks look good lowered. I lowered mine way low, had to use a bit pcb cover and bit heatsink and remove the stock cover over pcb and motor. Also had to grind down the little nubs on the inside of the truck bed. I glued on the tonneau cover after painting it semi-gloss black. It was a very tight fit, without enough room for the light wires to get back into the cab, so I removed the light. Think I got a pic around here somewhere. Here it is: |
1 Attachment(s)
I ended up using the motorworks pcb for another project, but the truck body lives on. It is on a microsizer chassis now. I call it orange crush. It has orange kit racer tires, orange antenna, orange gears, orange (2.6) motor to keep with the orange theme.
What exactly is the point of those lights in the cars, and where are they?
| All times are GMT -5. The time now is 04:20 PM. |
