-   Other Tiny RCs (http://tinyrc.com/forums/forumdisplay.php?f=42)
-   -   Kidriffic Micro RC 4x4 Monster Truck Dissection (pics) (http://tinyrc.com/forums/showthread.php?t=10856)
malform 05-28-2003 08:11 AM
I did a quad mod last night, I used the truck that has the bigger body so it all fits under there. I must say tho, I'm not as pleased with the resaults as I thought I would be. If there is any noticeable difference in speed it is very minimal. I can say however the run time is much longer, I got tired of playing with it before it was dead.
Should I have seen more increase in speed and power? Maybe I did something wrong?
Buzzbait 05-28-2003 09:21 AM
1 Attachment(s)
The quad-cell should be much more powerful than the stock dual-cell. It should be a little hard to control with 4 cells, and have a slight tendency to flip onto its back when starting forward.
If you went from 2 cells to 4 cells, and only notice an increased run time, you may have accidentally hooked up the batteries in parallel instead of series. Parallel will give you extended run times (current). Series will give you more power (voltage). Here’s a diagram of how the batteries should be connected, if you are running both extra cells from the battery in the back of the truck.
malform 05-28-2003 01:07 PM
Rock!
I went home at lunch to re-wire it.. I did have them in parallel. Now its awsome, much more fun than out of the box.
Thanks buzzbait.
Lord_Nick_D 05-28-2003 04:52 PM
also the more you charge it the better
I had to charge mine like 4 times to get the full power out of the batteries
and it didnt last too long
I added another 2 cells to the normal charger for a 3 cell car so is 6 cells chargeing a 3 cell car ok
rt450 05-28-2003 05:58 PM
i use a 9v battery for 2min. to charge my 3 cell.;)
Buzzbait 05-28-2003 11:14 PM
All of my modded cars go o a Piranha digital peak charger. The best $50.00 I ever spent.
http://www.duratrax.com/caraccys/dtxp4005b.jpg
malform 05-29-2003 07:31 AM
I was charging the quad I did with my super brain... But last night I wired both of the chargers I had together.
First I only wired it so it used 2 batteries out of the second charger. Then I ran the trucks batteries all the way down (took about 40 mins btw) and used my newly wired 6 cell charger to charge it just for a test. It maxed the truck out at about 5.2 volts. So just to make sure it does the job right each time, I re-wired it to be an 8 cell charger... Still need ot test the 8 cell charger. :)
Lord_Nick_D 05-29-2003 07:20 PM
8 cells is way too much your charging it with double the voltage
takumi_drifto 06-13-2003 02:30 PM
Man , i want some of those!!
so ur saying they come with extra bodies u can buy? or you just bought more Sets?
buzzkill 07-14-2003 03:31 PM
4*4 mod
has anyone tried to remove the gears and motor from the front wheels, to convert it to 2 wheel drive? is it possible?
malform 07-14-2003 04:11 PM
They steer like a tank, so you need the 4wd to turn :|
I have now idea why you would want to remove 4wd from something that’s already 4wd… That’s not an upgrade, it’s a downgrade :\
buzzkill 07-14-2003 04:55 PM
2 wheel drive
making a 2 wheel drive truck may speed it up a bit, it will also get rid of excess weight. and if you run the dual motor to the back you can still steer, (like a digi q)
Lord_Nick_D 07-14-2003 06:49 PM
yeah but turning isnt as good because these are not porpotional speed
steering with 4 wheel drive is easier
Just put a 3rd cell in it will be fast enough
squeegee 08-18-2003 05:38 PM
I know this thread is really old but....................I tried wiring my truck up with 2 extra button cells on back...........its wired perfectly fine. I think it's in my charger.........all I did was cut the plug off of the stock charger and rewired onto a 9 volt battry holder.............................What am I doing wrong, it doesnt work at all.
Lord_Nick_D 08-19-2003 07:18 PM
the 9 volt probably isnt supplying enough current to charge your batteries What I did was get a plug in wall transformer at the same voltage as the normal charger and use that to charge my tri cell truck
it works great
you should also charge it a couple of times
you also could have fried the batteries
