| enigma101 |
11-13-2002 07:49 PM |
Well I played around a little more after work today with the McLaren. I'm getting better at controlling it with a little more "time behind the wheel." By the way, the F1's use rear steering by varying the speed of each wheel. I believe this is the way other Digi-Q's operate? Sorry, but I don't have any other Digi-Q cars. Since the speed, acceleration, and steering is adjustable on the controller, I've been experimenting with different settings to optimize the control that is comfortable for me at my current level. I've found, so far, for the small area I've been running the McLaren in, I can get better turning performance by getting the speed and acceleration to about 3/4 or so of max and getting the steering to max sensitivity. I have to power-up a little in tight turns to get keep the little F1 cruising through the turn (careful!! Not too much or....wipe-out!:) ) and then back down on the throttle when coming out of the turn to keep from blasting out of control in the "straight-away." It's been fun experimenting with the settings and a little practice sure helps in controlling the little bugger. The little McLaren looks pretty cool to me going around my little circuit after fiddling with the settings, practicing, and concentrating. ;)
Speed? OK, I ran a little impromptu experiment, too. Please don't take it as "gospel" since I did it pretty quickly but here goes. I've got a Bit Racer IR timer and several Microsizers. I set-up a little 3' long drag racing-type "chute" with the timer at one end. I would have liked to have had a run longer than 3 feet but hitting the timer area can be a little tricky for longer runs. Anyhooo... I ran a Microsizer with the std. 2.2 motor 3 times past the timer, averaged the times and came up with a speed of about 1.5 ft/sec (starting from a dead-stop). I then ran the McLaren 3 times at max speed/accel. settings and came up with an average of 2 ft/sec for the little F1. Both cars had fresh charges. Again, this was just a "quicky" attempt to get some kind of speed comparison. I had the feeling the McLaren may still have been accelerating at the 3' mark but who knows for sure. I may be biased. ;)
I'm having fun with the little F1 and isn't that what it's all about anyway?
