check the balance post
hmm...hey arrive2defy...when-abouts are ya gonna send your stuff?
well first off, i broke my bit char-g (one wire was broken off) so imma send it to fanman to fix then try to make an interior antenna on it (guinnie pigs). if it works WAHOO! anyways since i broke my bit im bidding on a booster set on ebay with 4ch controller for 5 bucks! wahoo (actually its .50 cents but i proxied up that high... if you se it on ebay.. DONT BID!) anyways, when he finishes my curent bit and if the interior antenna works.. then ill send my booster to him to mod. of course imma give him some extra $ for all his help and pacients. :D if everything goes as planned ill combine both my bits to make an ultimate bit, the other will just be a backup or whatever. maybe ill hvae one for show and one for racing.. :D
hey, can i just get a radeos antenna and put it on my bit cahr g remote?
one fo those hard ones? yea! youll get like 50ft of range then!
its those antennas on those radios like a boombox tv etc.
omg, i finally got an antenna from my flashlight radio and put it on my remote, my car goes hafe a feet shorter thane when it had th stock antenna. y is dat????:(
hm... usually people would use tv antennas and radio ones.. try one of those or go to RADIO SHACK and pick one up for like 2 bucks. and make sure u install it right. then tell us how your bit is doin. sorry if the falshlight antenna doesnt work.. :(
thx 4 the replyz ;) . i tink i install it right. i got the instrucktions from www.bitchar-gmotors.com/howto.htm. do people actually use tv antennas ? those things r huge. anywayz , i have a boombox antenna but i sometimez listen to my boomox :( . or ill try 2 find a antenna from my dads radio.;) .
some people do use tv antennas but they may be a bit big.. im sure you can find diffrent sizes tho at your local electronics store. besides, even if your antenna WAS like 10ft wouldnt you think the range would be HUGE?! ;) just a thought... haha
do u tink if i cut open a slot 4 my redio antenna in my remote would it had been beter? cuz i didnt want 2 cut a hole on my remote yet till i see it goes good. so i tried closing the controler a little bit 4 the antenna sticks out. it didnt screw the remote bac yet i tested if the antenna works first.
i KNOW that if u put the antenna on the remote (4 ch or reg) itll boost your range up quite a bit. personally i wouldnt know cuz i never tried but from what i hear it will.
where is fanman, 323, wedge, tiny and the gang when ya need then? |
*snap!*
i'm awake...i have the hard antenna mod on my 4 ch. controller, and it helps some. I used to have about 2 ft of variable range on my scooby, and now i have anywhere from 4 ft to about 10 ft depending on how good of a day it is, and where i am in the house. My brother's loctite zexle used to have about 3ft and now has about 8ft on a good day. TheFanMan had a 4ch controller with a smaller hard antenna and the QFM twisted heavy gauge wire mod on his rx7 before he killed it. That thing got damn near 50ft... so, it a combination of both the car and the controller, but i think a lot more can be done to to the car. |
| All times are GMT -5. The time now is 02:32 PM. |
