-   Kyosho dNaNo Parts and Hop-Ups (http://tinyrc.com/forums/forumdisplay.php?f=159)
-   -   Atomic Dnano SSG DSP Kit (http://tinyrc.com/forums/showthread.php?t=24203)
Marcro 08-09-2009 08:29 PM
Hello again. Does this disc-damper work on both RM as well as MM? As I'm getting the Subaru WRX this week, I believe it is RM and I'd like to know if this will work on that as well.
Would like to get two of these if their worth while.
pedrocamp 08-10-2009 05:02 AM
I fit one to a RM 917 and it worked other than body clearance. One issue I have had though is the little plastic piece that sandwiches the chassis tab with the damper plate (c-shaped part that goes underneth the tab) sttrips out easily. The screws are too short, the holes too big and the plastic too soft. All those running the DDS here at Mooresville have fit longer-larger screws.
Marcro 08-10-2009 02:43 PM
Thank's for the info. It sounds like it'll be more suited for my Subaru which SHOULD have more room for it than my Murcielago. Also, thank's for the tip on the screws.
The 917 I think is the SMALLEST body and probably the flattest one as well, so I'm sure it's NOT suitable for the disc damper.
Marcro 10-08-2009 06:19 PM
I ordered some Dnano stuff from EGR Mart. Finally getting my starter kit with extra batteries, aluminum upgrades for the Countach, and a disc-damper for the Murcielago. I am curious as to how this will work in conjunction with an already fully hopped-up Murcielago. I wonder if it'll fit the Porsche as well. I will try it out on both.
I have the feeling that the Countach is much too thin of a body for the disc-damper to work on that car, but the Porsche 911 look's to have enough room.
I'll try it on both cars and if it works well enough, I'll get another kit.
Thanks for the info on that hole being large. I was thinking of using heat-shrink tubing on that post.
MrNanoTrax 10-08-2009 08:41 PM
damper fits comfortably on the 911 but doesn't make that much of a handling difference. the atomic damper won't fit on any of the flat bodies and takes up way more space than it should... one of our members installed one last week. i keep less than 2 in stock due its low "workability" factor.
Jellis 10-10-2009 12:17 PM
I wouldn't run any of my cars without the dampener plate no matter how much I had to modify the body. I know some of you don't want to mod the body but I'm way more into the performance than the look of the body.
IMO it makes a huge difference in the handling of the car
Marcro 10-10-2009 01:03 PM
Thank's for the info. I'll post what I think of it when I receive it. Could be any day now, possibly even today with any luck!
I'll finally be getting my starter kit too so I can drive the darn thing's! :D
nalves 10-10-2009 05:45 PM
Hi,
To use it in the Porsche 911 we need to modify the body?
Thanks,
Nuno
Jellis 10-10-2009 06:41 PM
Nuno I havn't seen the dampener in the 911 yet
MrNanoTrax 10-10-2009 09:40 PM
no, you can use the damper on the 911 with no body mods. fits perfectly ;-)
Marcro 10-23-2009 08:38 PM
I like it on the Murcielago, but it too requires a hole to be cut for the top.
I don't think it'll fit the Countach at all, but I plan on putting one on both Porsche and Subaru.
ub0211042 11-01-2009 02:34 AM
Hi,
Will the DSS fit onto Ferrari 360 modena without any mods?
Thanks.
MrNanoTrax 11-02-2009 08:27 AM
Originally Posted by ub0211042 (Post 207963)
Hi,
Thanks.
it should... there's plenty of space back there ;)
hamz9561 01-02-2010 08:36 PM
Will this damper fit without many mods on Audi R8?
MrNanoTrax 01-03-2010 10:07 AM
i believe it should... i'm supposed to be building a Race Spec Audi R8 for a customer here soon so get at me by e-mail for definite confirmation... the X-Power damper is actually better and slightly less expensive & has a cool led light ;)
