bitchar-a
Its a Toyota Celica
maan thats horrible packaging...the picture in the bottom right isnt even the same car..
but the car in the corner does look something like a 4 door Accord or other 4 door car |
bitchar-a
1 Attachment(s)
Here is another pic of it
Hey guys I finally got the bitchar-a in the mail the other day it seems to run fine and it has a long antenna about 2 or 3 times longer then my ZZ and faster then the ZZ with a 1.0 motor and it also came with a 2.6 motor the only thing I dont like about it is it turns sharper left then it does right any suggestions why it does that other then that Im very pleased with it
I bought one of those little Bit char-A's and they were good for some knock-around time.
However the quality of the construction wasnt really the best. When I went into reverse, the car would swerve to the left continuously. And the quality of the transmitter buttons wasnt better compared to the Bit char-G's. Sometimes the buttons wouldnt even touch the sensors. But if you were lucky to get a good Bit charA w/o any defects then u got a good car specialy wit the 2.6 motor. BTW i returned mine |
Well I fixed the turning problem all I did was put different back tires on it
I've never had any problems with my BitChar-A It's not as well built but I can't say it's horrible either. :shrug: It is pretty quick though.
As long as he did not pay that much, and he does not mind there is no problem. Some people seach ofr bt clones on purpose.
Well sence I switched the back tires I have not had any problems with it, the other day my brother got a nakamichi-n racer from wal-mart and it has a turbo switch on it and it has 2 batteries in it but there about half the size of the ones in the bits and the only thing you can hop-up on it so far with out taring it apart is changing the tires its the same size as the bits but you can take the motor or rear axle out of it because the motor and axles is in a sealed plastic housing, its as fast as my bit-a with a 2.6 in it with the turbo button on
| All times are GMT -5. The time now is 09:54 PM. |
