Cross Drilled brake rotors and calipers for looks:D
Aluminum screws because they are lighter than Ti. Metal wheel bolts. Parts containers and racks for easy, organized parts swap outs. And maybe a kit that containes everything you need to wind and build your own custom motor. Aluminum ring gears Carbon wings to match the hoods Carbon mirrors PEACE |
all the little servo/gear plastic made out of metal.
at least metal lining of the screwholes in plastic, because if you havent noticed, it doesnt take much at all to strip the PLASTIC threads separate body mount tabs that go in the car, so you could buy your own car model and convert it to an XMOD easily |
A seprate power supply for the lights. Like a watch battery or somthing.
don forget a nitrous system, hydraulics, 6 speed manual transmission, underglow(standard), wireless motors just like bit char-gs, real disc brakes that actually work, spinning rims, a carbon fiber hood and chassis, sound system, smoke exaust, opening and closing doors; hood; trunk, aluminum gears, and belt drive.
haha, belt drive. that slack and the stretchability of the belt would act like a slingshot. gun the throttle and it'll probalby zoom off after a couple seconds of getting tension in the belt. not to mention they break easily
-a 6 speed trans? .... HOW? -underglow lights pretty simple, buy a light kit (if you don't already have one... buy the LEDs from RS and attach them as you would if you were adding multiple lights... that's how I did mine -real disc brakes that work? I'm not knocking it , it would be cool , but it would be overkill in my book, unless you had something like a non-abs lock up the wheels kinda brakes -spinning rims? already made - c/f hood? It's not a real c/f hood but I have one (the stock one) that's c/f -c/f chasis? I'd love to see it -sound system? a fake sound system? or a working sound system? a fake one would be kinda neat to see a set of 12s in the back deck :D -doors? I don't see a point since the only thing inside the car is the actual parts of it aluminum gears? YES! -belt drive? no! -some new mirrors? let's get some M3 style mirrors! -more people in my state that want to have Xmod G2Gs !!! I'm not trying to say any idea is a bad idea... I'm just stating my opinion. I hope no one takes offense to this. |
i would love to see all of the drivetrane parts made out of mettal!! it would be heavyer but would never strip. ohh, yeah and a new type of drivesaft design, the 3/4 circles just dont cut it! the round themselfs out! |
anodized T-106 aluminum chassie and maybe some aluminum wheels? cause i broke the spokes on my wire wheels...
oh yeah motors like the SBP but allready together and not 50.00 bucks.........:D :rolleyes: |
I wanna see body top kits that come with body kits, maybe like 19.99 altogether.
A 9 volt battery kit with all the resistors needed to run it and not burn out the stock PCB. Or even Better a 9v X2 Battery kit with replacement PCB that will hadle 18 volts :)
A heat sink that actually works. Real Functioning Swaybars. Light weight Chassis. A body with see through windows and interior Light Kit add ons like strobing headlights or functioning turn signals. Liscense Plates A Minni Dynomometer Built to scale. So it read 800 hp... 900hp and not .03 hp. Aslo able to read Maximum Speed in MPH and in scale. A cleaning Kit with all necissary solvents and Lubes. Drive Shaft Kits Aluminum Suspension Parts. Swing arms... A arms, all of it. Toe Bars that don't have 1/64" of play in them. Flywheels Replacement: More acurate Steering Box Tires that don't fly off :) |
| All times are GMT -5. The time now is 11:08 PM. |
